Grain drill settings
MoMike
I have a JD 8200 drill without the small seed box. I've had decent stands of hay crops (orchardgrass, clover and alfalfa) using the main box, but I'm going to plant a small field to fescue, due to the variability of the ground. What would be the comparable setting based on buckwheat, sudan, millet, wheatgrass or alfalfa?
i have raised a lot of Millet,20- 25 lbs per acre in what you want,what setting that is on your drill i have no idea, and go ahead and fertilizer it, if you have a heavy stand it will go down, so some potash is good too.
This is what I bought sure makes it easy to plant different seed because there is a lot of seed that isn?t listed on the charts especially grass seed mixes
Seeder meter
