Needing Sickle Mower Rivets
Farmallb
Called TSC and 2 Farm and Ranch stores and Ace Hardware, No go. So What new thing are they using instead of rivets?
Farm equipment dealerships have them,the new ones aeren't as good as the older ones used to be.Most people are using bolt on sections these days I'd don't like the bolts except for in the field section replacement.
"[b:654c4848f0][i:654c4848f0]So What new thing are they using instead of rivets?[/i:654c4848f0][/b:654c4848f0]"
Ribbed bolts and lock nuts.
<a href="https://www.shoupparts.com/search-results/?term=section%20rivets&page=1">Section rivets</a> and <a href="https://www.shoupparts.com/search-results/?term=ribbed%20bolts%20and%20locknuts&page=1">ribbed bolts and locknuts</a> are available from Shoup 1-800-627-6137.
<a href="https://www.cuttingcomponents.com/catalogsearch/result/?q=rivets&order=relevance&dir=desc">Section rivets</a> and <a href="https://www.cuttingcomponents.com/catalogsearch/result/?q=ribbed+bolts&order=relevance&dir=desc">ribbed bolts and locknuts</a> are available from Webb Cutting Components 1-800-578-1480.
Hope this helps.
There bolts made just for holding the section on. I switch to them years ago and the nice thing is you can change a section right out in the field if one breaks etc. I picked up a box of them just a few days ago at Orscheln's farm an home. They also had the rivets
(quoted from post at 19:32:10 07/11/19) Called TSC and 2 Farm and Ranch stores and Ace Hardware, No go. So What new thing are they using instead of rivets?
Well, gosh, what brand of mower are we playing with, if Ford or IH or New Holland or DEERE, the local FIAT or DEERE dealer would have them.
You must have something exotic?
I?m the other odd man out I like rivers especially on a mower or a combine they do stink on a swather because you can never get the reel out of the way enough to get a good whack on the chisel to knock the head off . But on a mower it?s easy then i a have a tool to press the rivet out turn it around and it will clench the rivet nice and tight. With bolts you?ll have to change you hold downs to
Yep, I agree with you, and if it wasnt such a long distance, Id drive over to find out for myself
Hadnt thought about those. Deere is the only one I know of. Hate to see what they prize them at
tho. Its an OLD IHC simi mount mower
I was in my local Orscheln's today and they had the rivets. I was picking up rake teeth and they are in the same area so I made not of them having them. You can go to there web site and probably oder them
Orschelns
Best to buy an assortment box and that will have both the section and head rivets in that are longer and some knives will require 2 different length rivets for the head. Standard box does not have the head rivits.
