Baled for 40 years with a Vermeer Baler so notter issues are new to me. Got a 336 2 years ago and aside from a occasional missed bale, had had no problems with it. Last fall I had some straw to bale with rain due and I found that I was almost out of the 9000 twins. Rushed to TSC to get more. After paying noticed the box was damaged, so grabed a another box off the stack without seeing that they had mixed round and square twine. Found it out when I got home and decided to give the round baler wine a try. Mistake. Would not work. Next day I got 9000 twine, but the baler would only bale about 4 to 6 bales and it would stop tieing and I would find it hung on the billhooks or the wiper pads. Cleaned it out. 4 to 6, same story. After several times and not being sure how to correct, I parked and round baled. After talking to several online, I went back in to adjust the knotters. Note the misses were only on the right side and it was plastic twins. I found that one of the 2 clips for the wiper plates had broken off, Replaced that. Adjusted everything to what I thought was the correct settings and reset as best I could alone, Tried to bale some busted bales. Heard a bang and I che4cked to find the tucker plates were now at a 90 degree angle across the keedle openings. Released the pressure against the trip on the knotter frame and the plates poped back. Went thru resetting the knotters again. Tried again but this time the safety stop kicked in with the flywheel pin sheared and the lift arm pin shearing. I could not see any damage to the needles Obviously I'm over my head, any serrios suggestions n would be appreciated.
