John Deere 530 Baler
Yes
530 converging wheels
Possibly ? There?s an add in green magazine for a place that has round balers I?ll try to find it tomorrow
Two cylinder plus tractor salvage .
David and Robbin marlin
322 marlin prairie drive
Conway mo.
417 589 3337
www.2cylplus.com
I had converging wheels on a couple of different 435 balers. If baling in rough fields such as I had to the wheel pivot points get worn allowing wheel to lean over too far causing poor gathering of hay. I've since owned 2 JD 467 balers with Mega-wide pickups that don't require converging wheels to get the hay. I'd quit baling if I had to revert to utilizing converging wheels. Last baler with converging wheels I owned had aftermarket converging wheels with metal spring teeth that I liked better & think performed better than JD C wheels.
PS: rubber teeth for converging wheels are high $$$$ per section($89) with 6 required per wheel.
