Re: McCormick Deering No.7 and No.9
Are you pulling it with a tractor or with horses? IF tractor, remember that you need to take a 12ft
say, 2 X 4 and lay it on top the existing tongue. At the outside end, the 2 X 4 should be around
3ft off the ground. To compensate for this, you will need to make a underslung metal tongue that
drops down around 16in from the end of the wood tongue.
IF your using horses, what do you think might be a problem, IF you have the long tongue for it, OR a
set of front trucks for it? I have a #9, and I had a MH also, but have forgetten the #. I pulled
mine with my grandads 34 CC Case
