NEAFarmKid
Hi, I am new to this forum and I had a couple of questions for those of you who know a lot about horse drawn McCormick Deering mowers. I recently acquired my great-grandfather's No.7 Regular Gear mower that had been sitting in a side shed behind my house for decades. My great-grandfather had converted the mower to tractor drawn (and it will stay like this, I have no intention of using horses). I'm not sure what he pulled it with, but I am pulling it with a John Deere H in 2nd gear, so I don't believe that over-speeding should be a problem, considering top speed in that gear is 2.44 miles per hour. I have checked the oil and greased it, then tried it and was excited to find out that it worked. I have cut a little bit without sharpening the sickle, which obviously yielded less than satisfactory results, but even then it cut really good. It does have one slight problem. It leaks oil out of the gearbox onto the little flywheel that actuates the sickle. From what research I've done, this is a very common issue that comes from the flywheel's bushing wearing out. My grandfather told me that it's been leaking for a long time, and they had to refill it almost every time they mowed. I intend to fix that as well. Basically, I have given all this background to ask a question. What are the good, bad, and ugly "things" about a No. 7 mower. I would like to know because I intend to restore this machine. Also, before I forget, my aunt has a McCormick Deering No.9 that I would love to restore as well, so if anybody knows anything about those, it would also be greatly appreciated. Thanks in advance for all those who reply. Chris.
