Help identify this Farmall
Androo
New User
Hello! We just got this Farmall but we don't know what year it is, the man said he thought it was a 42 or a 46 but I can't find any pictures of those years to match this one. I'd appreciate any help, thanks!
It is a farmall cub they started making them in 1947
See if you can find a serial number
This site helps with serial number identification.
Oh ok, thank you, I will do that!
(quoted from post at 21:41:21 06/03/19) It is a farmall cub they started making them in 1947
The serial number should be on the front axle
support casting on the right hand side just below the
steering shaft. By the sheet metal I believe your
tractor was built after 1958. If the serial number
can?t be found look on the major castings for two
numbers followed by a letter, separated by what
look like screw heads. These give the
month/day/year of the casting and can be used to
(approximately) determine the year of manufacture.
You can find what year the letter corresponds to
online. Sam
That's a cub or basically a cub and they changed to a number designation. Like the A became the 100 or something like that.
