Bale wrappers
Dan Rodgers
New User
Hi guys, does anyone have an opinion on the Tube Line TL1000 bale wrapper. I'll only wrap about 80 -100 bales per year. Thanks.
I dunno, for that amount of bales /i think i may try to get a similar wrapper that will pick up the rolls and put them on the table, rather than the Tubeline which requires you to place the roll on the table.
I am thinking about my own wrapper as well. I have limited help and the drawback to the wrappers like you mention is you have to put each bale on the table. That would be lots of on and off equipment. I want a pull type with an arm to pick up it's own bales. If you have some help or do not mind the extra on and off Tubeline is a good brand if there single bale wrappers are as good as their line wrappers. Tom
Not familiar with the wrapper you are speaking of , but I have considerable experience with wrapped bales both individually wrapped and in-line. My first wrapper was just a turn table, and required two people to run, if you wanted to get much done. One person on the tractor with a grapple moving bales on and off the wrapper, and one person actually wrapping the bale. Fastening the plastic wrap to the bale, then running the turn table to wrap the bale, and finally cutting the plastic. Slow operation, but for a small number of bales economical. We made 500 wrapped bales each year, and it became a pain. So we bought a wrapper we could take to the field, complete with a arm to pick the bale up on to the turn table, and would both start and cut off the wrap, and dump the bale off onto its end. Only problem was, usually one, two and sometimes three of these functions would fail, and you were on and off the tractor, drove me nuts. Then after two years of fighting with this wrapper, I traded it on a new in-line wrapper, so far very happy with the choice. I now use half as much plastic as the individual wrapped bales needed, and it will wrap the hay as fast as I can push it into the wrapper all alone, and no need to have a grapple. We do over a 1,000 wrapped bales each year now. Not sure any of this is any help to you, just my experience. I would definitely go with a simple turn table wrapper if only doing 1-200 bales, but no more. Bruce
(quoted from post at 03:46:36 05/30/19) Not familiar with the wrapper you are speaking of , but I have considerable experience with wrapped bales both individually wrapped and in-line. My first wrapper was just a turn table, and required two people to run, if you wanted to get much done. One person on the tractor with a grapple moving bales on and off the wrapper, and one person actually wrapping the bale. Fastening the plastic wrap to the bale, then running the turn table to wrap the bale, and finally cutting the plastic. Slow operation, but for a small number of bales economical. We made 500 wrapped bales each year, and it became a pain. So we bought a wrapper we could take to the field, complete with a arm to pick the bale up on to the turn table, and would both start and cut off the wrap, and dump the bale off onto its end. Only problem was, usually one, two and sometimes three of these functions would fail, and you were on and off the tractor, drove me nuts. Then after two years of fighting with this wrapper, I traded it on a new in-line wrapper, so far very happy with the choice. I now use half as much plastic as the individual wrapped bales needed, and it will wrap the hay as fast as I can push it into the wrapper all alone, and no need to have a grapple. We do over a 1,000 wrapped bales each year now. Not sure any of this is any help to you, just my experience. I would definitely go with a simple turn table wrapper if only doing 1-200 bales, but no more. Bruce
Bruce, I have photographic evidence of you getting wrapping halp from a nice looking young lady.
