Ford 130 plow coulter bearing
JHEnt
Has anyone found a source for these bearings? Or even if there is a bearing number aside from the Ford part number to search for. These seem to be a really odd size.
jhent, perhaps they are the same bearings that White plows used? I know Ford used some of the same parts as White in their plows so maybe the bearings are also the same.
Did you try the New Holland dealer. I had trouble finding the right bearing for an old IH plow I have, I finally stopped and checked the Case-IH dealer. He asked how many I needed and got one off the shelve, then gave me heck for not coming their first.
We took a good one all apart and found a bearing number from the bearing manufacturer.
AS4508FD. It's a very large bearing with a 7/8" round hole.
These are not available from NH and was hard to find a cross over for it. However several bearing companies do offer a similar bearing but with a 7/8" square hole for a disc gang. Seems like that will work at least. I cannot find a round hole bearing that same size.
Now the Coulter that the bearing failed in has the lip of the bolt on flange broken out. We are going to have to figure something out there because again, I can't find a flange or hub that matches those Coulter hole pattern.
