Texasmark1
Last thing I did last fall was to install a new 3000# high pressure relief valve on my 375 roller since I had been running around 1500# max on my bales and they were sloppy and I had done several other things, that were needed but didn't solve the problem and as you recall I had conversations with you on the subject.
Yesterday and Today I was making hay and the pressure hit the relief on every bale over the two days and I finally got bales that I had a hard time getting "stuck". I was baling combinations of Fescue and clover in one field and Austrian Peas and Rye in the other with big fat WWs. Hardly ever did I have to ZigZag to get an even bale as the pressure hit early in the bale formation and I assume that helped to spread the incoming across the rollers. Just wanted to let you know.
