Landpride DM3506 disc mower hyd. cyl.
eye4iron
The hyd one way cyl has a small hole and check valve on the barrel end of the cyl. The hyd. hose end is on the rod end of the cyl.
When I raise the mower disc arm to the vertical position oil will squirt out of the check valve at the end of the stroke.
Has anyone seen this before?
What is the little check valve/ball for?
