Sickle mower
292 Ralph
I have a IH Pittman less sickle
mower that I am working on I
need to pull the eccentric shaft
out of the wobble box down I
have the gearbox torn down but
cannot figure out how to pull
the shaft out thanks Ralph
NOT sure what exactly you are trying to remove, but if pin, Key # 21, it is internally threaded and you screw in an appropriate adapter on the end of a slide hammer puller and yank it out.
<img src = "http://cnh-b2b.ptcmanaged.com/index.php/sbsimage/CSIH/default/1194712.png">
I had my wobble box overhauled by Rouse Rakes in Burwell, Ne for under $400. It included all new bearings, a new bushing and pin for the knife arm. Plus they have all the special tools to set up the box correctly. They are very good in what they do and manufacture all the wobble boxes for the mowers made today. You might consider calling them.
