Just purchased a 800 cyclo at an auction and am looking for a little insight on it. It's currently set up as an 8 row 15" and my best guess is it was an 8 row 30 that someone changed around. Going to use our 706 to run it is my plan. It appears the previous owner had it running the pump off tractor hydraulics but it came with a 540 pump so my plan was to mount a small hydraulic tank on the tongue for the pump and use one of those lever flow control valves to set my air pressure. Not too familiar with these pumps but would I be able to run a 1000 to 540 adapter so i could drive about half throttle or does the pump put out enough pressure I'll be able to run at half throttle off the 540 directly. Other question is how are most of the markers plumber? This goes to a hose with no fitting on it that I assume the previous owner kept. Do you guys like to run them separate or plumb with the lift?
