Engine swap in 730 or 830 case
Mini Eagle
New User
Hi guys. Had a few cases but just wondering what i
may run into or if its possible even to put a 6
cylinder from a 930 into a 730 or 830. 930 is 6
speed wet clutch comfort king. Other than the
obvious hood difference can i plug the oil feed to the
clutch / wiggle pin plug. ? Bellhousing looks same
but bigger bolts. Would like to use on pto work
mainly and really like 730/830 and caseomatic as
well thanks and looking forward to some insight
The engines from the six speed tractors have a different bell housing configuration than the 8 speed 930, 830 and 730. Won't work...but the engine from a 8 speed 930 will fit a 7-830.
Okay. Is it a different bolt spacing ? Size or shape ? Looking side by side look close except the bokt sizes etc
I seen a 2670 engine in a 1030, at a tractor pull, i went and made a point and talked to him later, as soon as i heard it run, i knew it wasn't a 1030 eng!
Like Steve said a six speed engine Does Not fit a 8 speed unit,, not even close to bolting up lots have tried before none made the install
