ditchwitch
I have a 5 foot King Cutter Bush hog and i need to tighten the bolts up on the gearbox. I have taken the blades off and the nut for the stump jumper but the jumper refuses to budge. I have heated it up with a map gas bottle pretty good and hitting the jumper with a 2 pound hammer and a big chisels. Spinning the jumper 180 every time hitting it through the hole where you take the blade bolts out. The jumper has never been off. Is there a way to tighten the gearbox bolts without taking the jumper off. I have tried and looked and it doesn't seem to be. Just wondering if anyone has come across this before and what yall did to fix it. Thanks in advance
