Lastofadyinbreed
New User
Hello!
This weekend will be my first plow day with a 44H plow...
I have a 44A that I have used quite a bit but it doesn?t have the hitch rod and spring like the 44H does. So I am reading the manual and it says the double nuts should be spaced approximately 1? from the back of the rod guide ?under normal plowing?...
So my question is do I adjust for that 1? before I head into the field? Or should that be adjusted with the plows in the ground?
Other than that I have everything pretty well adjusted and ready. Hoping these will work well. My 44A was a decent plow but no matter how much I tweeked I could never get it to plow quite as well as either my Oliver 100 Trip or My IH #8. Thanks for looking in, I look forward to some good advice!
