Do I need rear wheel weights for JD B?
Eboor1995
I have a 43 JD B and are getting new tires and rims due to calcium chloride rotting current rims and tires. I am thinking about putting 300 pounds of Rim Guard (beet juice) in each tube it?s supposed to be non crossive and good to -35. I will be using it to pull a 2-14 plow. Is wheel weight needed for that? and if so how many pounds should I put in each tube max is 385 for 75% fill
I pulled a 5 disc tiller for years in our tough soil here with a JD A and had no weight in the tires. The cast wheels were heavy enough. I hate fooling with liquid in the tires.
Richard in NW SC
Do you have the pressed steel wheel or the cast wheel? But you absoulty do need extra weight. I had a 46 B, same as yours with the cast wheel and had 3-400# estimated homemade concrete weights on each rear wheel pulling 2-12" plows. If your ground is very easy working and pressed wheels then the fluid to max might just might work but for me I would have had to have more weight. And I could not pull 2-14" too much load. Now the cast wheel then the fuid should do you.
Pulling that tiller is way different than pulling that plow plus an A is way heavier. No compairson
Keep your rear tires at around between 20/25lbs. I had a 50 B, and although I imagine they had bumped up the hp by then, I could plow on the level and downhills in 3rd with a 2 14 Moline rope trip plow
(quoted from post at 13:41:19 03/04/19) I have pressed steel wheels and cast iron wartime frame and I will be plowing in southern Iowa
You need extra weight. My '45 A with pressed steel wheels was quite worthless pulling a 2-12 to 2-16 plow until I added two F&H weights on the land wheel and one on the furrow wheel. I am mostly happy with it now. I don't remember how much they weigh, maybe 90 lbs each? Sandy clay loam and silty clay loam around here. I think I remember wishing I had more weight at the Belmond, Iowa show where they have clay loam soil. If you're in a hilly part of Southern Iowa, you could use more to climb the hills.
This ol gal weighs 9700 pounds it?s got max fill of liquid rust and 7 front weights it?s a little bit on the heavy side but it pulls nice . Going to remove the liquid rust eventually and go with 3 cast weights which drop me about 500 pounds
If the cast wheel that would be good, pressed steel will still need cast weights to equal the weight of the cast wheel.
