Dunham Lehr 22 Loader Mounts for '79 Ford 4600SU
sstorm
New User
My husband is working on a Ford 4600 SU he purchased with a Dunham-Lehr Model 22 loader. Does any one have information and/or pictures of the proper mounting cradle and brackets for this combination. We suspect that the brackets on our tractor bear little resemblance to the stock setup and would like to build or source the proper mounting cradles. Thank you very much.[/b]
I have the newer Farm Hand 22 for my 4000, the back cradle should be the same but I've never seen that loader on a set back axle tractor, no idea what the front bracket would look like.
Would there be a chance you could post some pictures of your mounts? It might give us a clue where they started from.
I can't help with a picture, but it is a one piece assembly that bolts to the center of the tractor, and to the front bolster, under the radiator. It will most likely fit all the 3 cylinder Ford tractors with swept back front axle, from the 2000 through the 4610 SU. The universal mounting kits won't work, due to front bolster being behind the sheet metal at front of tractor.
HTH, Dave
PS: Check the photo gallery for Ford 3910, by Shetland Sheepdog. There are pictures of the loader on my tractor, but the mount doesn't show real well.
s storm,
re loader mounts:
E-mail me at d n sea ger
at my fair point
dot net
and I can send you some pictures of the loader mount on my 3910.
HTH, Dave
