Re: White 253 18’ manual fold
young mechanic
02-05-2019 17:47:31
Main thing for leveling is, adjust the big crank that sticks up next to the hyd cylinder. The crank rocks the disk forward or backwards depending on which way you turn it. If there is a ridge at the edges of the disk then the front is in to deep, if it leaves a ridge In the middle of the disk the back is in to deep. Just takes a few passes to get it set. You can also change the angle of the gangs on those disks.
