Both the master cylinders are leaking and they have the hyd.depth control rod.Can I replace these cylinders with regular cylinders and use spacers for depth control? Or should I repack the leaking cylinders? I believe a regular cylinder would still flow oil to the slave cylinders on the wings. Just bought this cult. The master cylinders with the limit stop for depth control is a internal oil bypass,so I'm not sure how this will trip the Hyd.control lever on the tractor which needs to see back pressure to trip.The two masters cylinders are missing the stop collars that clamp to the shaft not sure where I can buy just the stop collars. Thanks for any help.
