McCormick #39 plow hubs, wheels, tires.
b2farming
New User
Hello, I just purchased a model 39 plow, it has mismatched car rims and bad tires. I was curious what was standard equipment tire size for this plow, or if there is an implement size more appropriate. It currently has 7.50x16. I'd also like to know if the 6 lug hubs it has were factory, I haven't seen anything but 4 lug/8 hole combos. Thank you, Nick.
Per the parts book a 27 inch diameter steel wheel was standard, IH part number PO 21 998. Options were 4.50 x 16 rubber tire with rim (part number 16 632 W) or
5.00 x 15 rubber tire with rim (part number 453 631 R91). The full rear wheel assembly for the rubber tire options were POW 525 for the 16 inch and POW 584 for
the 15 inch. Keep in mind that many can or were cut-offs.
Here is one that has been restored with rubber tires. It is on 8 bolt rims with implement style tires. The picture in the parts book shows an 8 bolt rim also.
Please cancel the middle photo. It was posted by mistake.
