Rolling damp hay
SHALER
I have a Vermeer round baler that is commonly known to not like damp hay at all. Therefore I have not ever knowingly baled damp hay with it. My question is this- if you
do happen to attempt to bale damp hay that the baler does not like, what will happen? I assume and have heard that the hay will wrap around the belt rollers. If that is
true, what happens then? The belts simply stop turning (slippage) and the baler plugs up?
With my Gehl,the first clue is that the bale won't eject like it should. I have to back up and hit the brakes a time or two.
My F has baled more wet hay than dry. Hay around here is grown on ground too wet to raise grain crops, and all it does is rain and rain. I make small squares of the good quality hay, the round baler is to get rid of the junk hay.
The roller with the flaps likes to ball up.
That?s about the worst of it.
Have to be aware of wet hay heating and catching fire.
Paul
I suppose that works in your climate.........
Here, my back yard, there are times that helps, and times it just rains and or is 90% humidity for more than a week at a time.
You can rake every hour and it won?t matter.....
Paul
(quoted from post at 00:11:46 01/14/19) I suppose that works in your climate.........
Paul
Then you either need a tedder or to start making baleage.
Your question of what will happen to your baler if it plugs with too wet of hay is very model specific. On some it indeed wrap the rolls tight and the belts will stop/slip. On others the roller can wrap tight enough it can break shafts and rolls. So post your model and we can tell you a little more information.
