Landpride 7? Disc Mower Hookup
eye4iron
We just retired our sickle mower. Any information about a disc mower is appreciated. Landpride disc mower that we just bought. It has a link that I believe
is part of the break away arm. What kind of bushing goes on the post
and inside of the arm? Just any old bushing that will fit? Does it get a
washer before the lynchpin?
I would look for a sleeve and a bushing that will fit inside it and over the pin. If you can find them you could weld the sleeve permanently into the hole, then use the bushing to take up the space and replace it when needed. So far as disc mowers in general the most important thing to evaluate them is to assess play in the gearing. If you find that any one disc has more play either up an down or side to side than the others, you have a bearing going out.
