Daniel waldner
Thinking about buying a haybine vs discbine and wondering if haybines have a hydraulic tongue? I'm interested in models 492, 1465. I'v seen some with it and wondering how common it is.
Thanks
Thanks
(quoted from post at 13:58:22 12/28/18) The reason I want a hydraulic tongue so you don't have to drive just perfect when mowing.
(quoted from post at 16:29:54 12/28/18) Will it plug the mower if you overlap slightly into previously mowed areas?
(quoted from post at 21:05:32 12/28/18) What would you recommend for a smaller discbine?
(quoted from post at 20:29:54 12/28/18) Will it plug the mower if you overlap slightly into previously mowed areas?
(quoted from post at 15:12:53 12/29/18) Do you know of any other smaller 9' discbines that are cheaper and easier to run?
(quoted from post at 19:20:28 12/30/18) Also what's the best way to check for wear in the wobble box when it's at a auction and you cannot run it?
