Made the deal on a New Holland
SVcummins
D1000 midsize baler today . Kinda excited to see
hoe it does
Untitled URL Link
Bet you are the first one on your block to have one of those. Looks like one of the first series of big squares New Holland ever built.
People don?t know how to feed round bales I like them just as good or better than anything stand em on end and you can feed of em as easy as square bale
You can haul more with sqaures on the same size trailer. With round bales you either loose some of it from waste just rolling it out or you buy a processor which is more cost. Yes you can throw them in a feeder and let cows much off of them but that?s not practical for 200 head. We use round bales but would like to go to square someday.
We haul semi loads of round bales they?re not bad at all as far as feeding we use a hydraulic unroller to feed them in the feed grounds One man can feed a lot of cows that way . Big bales are ok but somebody needs to pitch em off the rack or use a hydraulic bed or a big bale processor
Hope it works out for you. My thinking is you will need more tractor in front of that baler, than your 4020. Guys I know that run big square balers, put 150 hp tractors on them. And if you are going up hill making hay bales, you can see a puff of exhaust come out of the stack on every stroke the baler takes.
It?s not a real big baler it?s a 2x3 baler a 3x3 baler pulls harder and 4x4 baler harder still Heston recommends 90 hp for a 3x3 baler I?ve pulled Heston 4x4 balers with 200 hp and they will work the tractor hard depending how much hay you shove through it . I bought the baler for less than scrap I know it needs some repair work I?m not even sure if it will be running next year or not and it needs a lot of parts it will probably go to scrap
