Plow identification
Oscar669
New User
Can anyone help me identify this plow so I can find a manual, parts, and operating instructions.
Thanks
thanks for the replies I will get in touch with you at some point Steve for a manual. real busy for a couple weeks. found a PDF parts manual on line but not an operation manual.
Remember there is a small frame 10" or 12", Scarce, medium frame 12" or 14" and large frame 14" or 16", common, setting and width is adjustable by switching the vertical part of the shank from front to back and moving tail wheel and reversing furrow wheel to make the proper setting for the smaller or larger bottom cut. And same moldboard is used for every size from the 10" to the 16". And on that plow you cannot measure width of cut like most other plows. The small frame will measure 11", medium frame 13" and large frame 15". I had a medium frame with hydrolic lift or a 44H plow. All in same book. My book actually does not list the small frame model.
