Farmall C-72 Grader Blade for Super C Missing Part
I have a nearly complete C-72, but I need the oddly 5-sided (sortof) bracket that mounts to the rockshaft. Right now the setup is not quite correct, and I bet the IH design was better. I have a copy of the manual, so I know what I'm missing.
I want to plasma cut the shape here, can anyone trace the part for me, and supply a couple key dimensions so I can scale the rest?
Thanks
Andy
You might post over on the IH/Farmall board, as I know there are a few that frequent that board that have those blades, and would probably be happy to help out.
(quoted from post at 19:19:40 11/16/10) I have a c-72 blade. Let me know if you still need the parts traced. Matt
Yes I would like a tracing of the odd 5-sided bracket and the hole-hole length of the arm that connects that bracket to the front lift arm.
thanks
Andy
I took the part off the tractor and still need to trace it. sorry for the delay. I was going to trace it on paper. do you have an address i can mail it to. thanks Matt
Sure
Andrew Hirzel
545 Washington street
Otsego, MI 49078
Also, what is length of the rod that extends from that bracket to the front lift pivot? thanks
Did the trace help? I have two of the blades and was missing the same part you were on one of them. I made the parts by heating and bending, but I like your idea better.
I need the same thing. Would anyone happen to have a bracket they would be willing to trace?
Thanks,
Dan
