New Holland Rake ???s
Ok, i think i bought a hay rake. Only thing is the left tire is rubbing against the frame; with the tongue on the ground. Is something out of adjustment here?
I've used a rake like it years ago, but don't recall much about serviceing it.
It's about 60 miles from home... how fast can i safely tow it behind my truck?
Looks to me like the tire is too wide.plus it'd be better to be able to take the shaft off the drive hub going to the gearbox you'll need some washers and a bolt to take up the slack.
any way you can turn the wheel/tire around?? mount it from other end.. switch tires see if helps.. just shooting from
the hip.. longer bolts with spacers not recommend for long haul.. trailer it home..
I have a 56 and it is a great rake. I have 195-70R14 car tires on it and they work fine
I pulled the above off an old post on here about tires this guy used..
Thanks guys for the quick reply. I've turned tires around on implements/trailers before...also used spacers/nuts/washers...but its been years and forgot all those tricks of the trade. The offending tire is almost new...i hate to replace it.
how do i pull the drive shaft going to gearbox ? The rake is 15 miles from me; may get it here, then work on getting it to farm.
Baby steps...
PS, owners/operators manual??
I have seen a lot that people run'em till the wheels fall off. There are two tapered roller bearings that hold the mainshaft on each side and a bushing for each wheel. I've towed them at 55 before but I put tubes in mine cause they go flat if left sitting too long. You can tighten the wheels with washers but the bushings have to be in fair condition or you will need a new hub or put a bigger bushing in it. I think when the driveshaft is disconnected they run mainly on the tapered bearings. If they aren't totally worn out you can tighten them with the big nut on each end. Watch out for someone with their head down on the road. I think you might want to make sure the gearbox isn't shot.
Take the shaft off the nd of the axle and tie it up. You do not want it jumping into gear at 35mph! Easy to happen, you?ll never find all the little pieces and wouldn?t have
need to it would be scrap.
My 55 has little latches in the hubs to take the dogs out of gear as well, donno if the 56 does?
Probably turn the wheel around as mentioned. I had to on mine when the skinny tire blew and I had to put on a fatter one laying around.....
The bushings or bearings (again, not sure of the differences between 55 and 56) in the hub might be loose or wore down and wobbly on the axle. that would not be
good at speed.
I?m kinda mentioning the bad, don?t mean to scare you it should work out.
Paul
Way to big of tire on there that?s why it?s rubbing .
As far as parts new Holland has about anything you
need and there are a million of those rakes out
there for used parts
As Paul said you pull the drive shaft from the axle end. It is supposed to be held by a pin held by a spring clip but you will probably find a rusted bolt and nut. The drive coupler telescopes and the two ends tend to get rusted together. You will need to lift that end of the basket in order to get the coupler loose from the axle.
The larger the tire the slower the raking assembly will turn.If its the right factory wheel on it correctly now turning the wheel around will make the tire set in even closer.
(quoted from post at 06:33:51 12/12/18) If that shaft is rusted tight it'll destroy the gearbox and the universals.If it is he needs to closely inspect the rake before buying.
If the shaft is rusted right, will some heat (torch) and a big hammer free it up? Thinking out loud here.
No one wants to buy the smaller tires those rakes came with, probably why it is rubbing. They all have some play there. They rake faster with the smaller profile tires. Bigger car tires, especially if they slip or are a little different size, will cause them to speed up and slow down. I can't tell if it is a 55, 56 or 256 from pic, but some of those parts are now available aftermarket. 55 has 6 hole rims, 56 and 256 have 4 hole.
(quoted from post at 15:58:00 12/12/18) No one wants to buy the smaller tires those rakes came with, probably why it is rubbing. They all have some play there. They rake faster with the smaller profile tires. Bigger car tires, especially if they slip or are a little different size, will cause them to speed up and slow down. I can't tell if it is a 55, 56 or 256 from pic, but some of those parts are now available aftermarket. 55 has 6 hole rims, 56 and 256 have 4 hole.
Elton, he posted a pic of the plate that gives the model #.
I did not see it, but do now. 56. I have had those drive shafts rust up solid on those rakes, they need to be able to slide. But not much difference in the way any NH works, but parts for the 56 and 256 will about all interchange. The 55 is older, different gearbox bolt pattern, wheel bolt pattern, and the bar bearings are different size.
