where to source PTO for post hole digger
I have a 3 point post hole digger for which I need a complete PTO driveline. I believe it is about 5' long and the farm stores carry only 4'. where do you recommend sourcing the pto driveline for best value/price. thanks,
There is a company in Lincoln, NE called Inline Truck Parts and Service. They make drive shafts. Not sure that they are the cheapest company but they do very good work. They do a lot of drive line work including PTO shafts. They can make just about any thing in PTO shafts and that is where the costs comes in. If it is a basic U-joint the cost is reasonable. If it is a special one or special tubing, that is where the expense comes in. I have had work done by them before and was well pleased.
Agri-Supply has a good selection, but there will be significant shipping depending on where you live. Has anyone ever installed a slip clutch (like on a cutter) on an auger? I see Agri-Supply has driveshafts complete with a clutch quite reasonable.
Start with an older welding shop in town,I know two shops that have every piece of a shaft in stock.
As most have stated there are several places to purchase PTO shafts, I personally go to a shop in town and they custom make it per my specs. Cost a bit more but it is worth it to me, they also repair shafts. If you can find a shop like that I would go that route.
you say 4 ft is that for both shafts or one if it's one then you need two shafts the male shaft and a female 4+4=8 you cut for fit
I have tons of shafts and joints plus yokes some not even made now the pto for the digger is 150 complete email me for details
no places like TSC have shafts only about 4' long I have the original tube and it is longer but shot. the collapsed length needs to be more around 5'?
Just a comment on the subject. Those post hole diggers will bend internal hydraulic parts if you dont watch them good.
Pull up post hole digger PTO shaft. I forget the name of the company but they have anything you want for a digger.
I bought several of the cheap (vs premium units) brands from ASC over the years. Never had a problem. Gotta ensure that you get the size to do your job....in addition to the correct length and interconnect yokes....like spline-spline, or spline-pinned sleeve.
