7? drag disc question?
Eboor1995
I am thinking about buying a drawbar hookup 7? drag disc. The guy said it is stuck in v and don?t straighten out like it should to make easier transporting. Is that a common problem and easy to fix? I don?t know the brand or anything about them thanks for your help!
(quoted from post at 04:12:42 12/01/18)
I would think the disc angle adjustment mechanism even if stuck tight should not be too difficult to free up with some heat & lubrication.
Jim, don't forget the BFH... the drag disk dad bought used 35 years ago still works great... the disks are wore thin from use, he was a firm believer that grease was cheaper than parts, maybe that's why it still works.
The ground here is rocky and i had to idle in low gear going from field to field... gonna use it soon.
