ford 101 plow
901sos
I have a 3-14 3pt hitch 101 ford plow & need a tail wheel for it. I have the bracket & hub just need the steel wheel. Anyone
on here have a GOOD one they would sell?
Not sure just how that one is made but a friend has had several made for older Deere plows.
What he is needing is a rolling landside. The Ford 101 did not use, or need a tail wheel as it is a fully mounted 3 point mounted plow, but did use a rolling landside. Of course I have heard this part called a tailwheel more times than properly called a rolling landside. A tailwheeel carries the rear of the plow and a rolling landside presses against the side of the furrow like a landside.
An MF tail wheel assembly works well. They're spring cusioned and wheel doesn't break like the Ford's which is rigid
