Generally speaking I believe here are the ways you can wrap a bale, please correct if not accurate:
Plastic or sisal twine
Plastic netting
Net wrap fabric
Thick net wrap known as "B" Wrap
Plastic wrap or sheeting on outside circumference of bale only
Finally, completely plastic sheeting wrapped bales (baleage)either individually wrapped or in a tube.
I put these in order of what I think give the bale from the least to most protection from the elements.
If you were rolling bales for resale and could not store them inside, what wrap would you choose? Consider the baleage options off the table as they can require different handling and wrapping equipment (versus a different end product - baleage vs dry hay).
Plastic netting
Net wrap fabric
