WAYNE-N-TEXAS
I'm about to get back on the baler. The problem was it gave me a signal to dump the bale. You said check the latches and make sure they had the right clearance, which one didn't.
I had to stop and do other things for a while, I did order some new shims with one that has the square hole.
My question--looks as if the spring is loose that attaches to top of that latch, can I just tighten the spring until I get some tension on it? What will I mess up, which I beginning to get good at?
