J I Case disc harrow
silverstreak
New User
I have a J I Case disc harrow and am trying to find out what model it is. Just guessing at the age I would think it is a late 60s, early 70s disc. it is a 9'9" offset wheel disc and appears to be very heavy duty. It has 1 1/2' round axles. I need bearing housing and bearings for it. Casting numbers I have located on different parts is as follows:K-2579 is marked on the axle hub that attaches to the rim of the tire; K-4175 marked on axle nut and hub; K-3020 marked on 9" spacer spool. Any help would be appreciated.
I have ordered disk bearings from shoupparts.com. Have got arbor bolts from them cheaper than the local machine shop can make them. Size may
be the same even if not listed for Case.
(quoted from post at 16:41:04 10/29/18) need pics of it to tell you what model
cnt
Not really a pic of the whole disc like I wanted but it appears to be a model 400 I have been looking for one for many years seem to be hard to find in my area as I have yet to see one, I know we never sold one new either,
It sure looks very similar to the disc I have, this helps a lot. Would you have any idea as to what year they were built? Thanks a lot for the information.
the lit I took that pic from was 1967,, I will look and see if I have parts book as it may give production dates, I see cih on line does not even list them but thats no surprise there either
cnt
I talked with Shoup and they have nothing for J I Case. Does anyone know who I might contact. I need bearings, bearing carriers, 9" spools, 1 1/2" round axles.
Yes they do,, have them look up the axle size in their chart, I have bought them for my SA series Case disc,, they do not list them as Case I just looked in the book and found the size I needed, many disc parts interchange
I have this exact same plow and I am in need of bearings. Did you ever find out what bearings fit this plow and where did you get them from?
