Company Logo Shop Now
TractorLinks.com
John Deere FBB
7060
10-10-2018 17:56:11
[list=]
I just bought a John Deere FB-B grain drill with double disc openers. I notice the discs are pretty loose. Are there bearings in there to replace or is that just how they are? Looks like a plug in the end of the hub. Anything I should know about this drill? Thanks[/list]
SVcummins
10-12-2018 18:43:58
 Re: John Deere FBB in reply to 7060, 10-10-2018 17:56:11
third party image
third party image
7060
10-12-2018 16:37:17
I have the cast iron hub that is riveted onto the disc. They are pretty loose on there. John Deere wants $98 for the disc opener assembly. And to buy just the hub and bearing it’s almost $120. I would need 30 for a 15 hole drill so that prices them out. Not spending $3000 on a $700 drill. My disc opener comes off by removing a 3/4 head plug and then unscrewing the assembly though the hole with a 3/8” extension and ratchet. Can I shim it somehow to take some slip out or can I convert it to a sealed bearing disc opener?
SVcummins
10-12-2018 16:48:03
 Re: John Deere FBB in reply to 7060, 10-12-2018 16:37:17
According to the book you can repack that iron bearing and the adjust it if I read it right and you can add a new felt washer then if it rubs the cast iron opener housing you can grind some of that casting down so the discs will spin freely
david from kansas
10-12-2018 06:53:32
Not familiar with that old of double disk openers, but if it has the same chilled steel bearings as the single disk openers, I may have some of the NOS parts like the felt washers and retainers if you need them. I replaced mine with the sealed bearing disks many years ago.
SVcummins
10-11-2018 19:32:14
third party image
The take up washer is still available
SVcummins
10-11-2018 19:27:35
Theres a hard iron bearing and anti friction bearing option . The hard iron has a grease zerk at the top of each opener. The anti friction has no zerk . Reading in the manual you can repack the anti friction bearing and there is also a shim you can use to take up slop . The plain bearing you can tighten and a fiber washer
Bob
10-11-2018 17:45:53
"the roller bearing option the plain bearing you can tighten the roller bearing you run till it falls off and then buy a new bearing"
SV, I hope that makes more sense to you than is does to me!
SVcummins
10-10-2018 21:21:53
John Deere had a plain bearing option or a the roller bearing option the plain bearing you can tighten the roller bearing you run till it falls off and then buy a new bearing . Shoup has the disc bearing and all for about 18$
Leroy
10-10-2018 21:08:31
Plug in end of hub probably cover the allen head of bolt to hold them on, one right hand one left hand bolt per pair of blades. Was how IHC had it. For wht tipe of bearing just go to the JD parts lokup page and look at the parts book.
