Company Logo Shop Now
TractorLinks.com
Ferguson D-EO-20 Rake Bushings
cow
10-09-2018 12:22:01
Wondering if anyone would have a clue on this, I just got a Ferguson D-EO-20 hay rake. It's in rough but functional condition. Noticed a lot of free play in the bars and after some looking I figured out I'm missing several rubber bushings.
They're 21 in this parts diagram http://driedhotpeppers.com/images/Hay_Rake_pics/FERAKE08.jpg
http://driedhotpeppers.com/images/Hay_Rake_pics/FERAKE07.jpg
Part # S-10098 Bushing-Rubber.
Is there any chance these are available somewhere? I have the feeling I may have to find some kind of hunk of rubber and make replacements myself... anyone know a good source for that?
ptfarmer
10-11-2018 00:03:12
 Re: Ferguson D-EO-20 Rake Bushings in reply to cow, 10-09-2018 12:22:01
Number 39. Ferguson S-9863 should be CR WC87504
Number 41. Ferguson S-9864 should be CR 6200-2ZJ
third party image
Cow
10-10-2018 22:36:42
The bearings that go into the big spider wheel and connect to the bars. The big main ones seem to be pretty solid. I pulled one of them out to inspect it and it's kind of an oddball thing. There are really two bearings, one big one in front and a smaller one on the rear on a sort of cone shaped part with a stud coming out where the bars bolt to. I'm not sure if they might be press-fit on or what. They all turn and none of them are horrifically wobbly but a lot of them don't feel great either.
I can probably grease it really well and run it for some time as is but a lot of those studs are beat up- I think they were supposed to all have slots for cotter pins but some are partially broken and rigged up with jam nuts, the one I took off wasn't completely straight either. It looks like that whole thing is one big assembly with the conical shaped section/stud being all one part. I suppose the bearings are pressed onto it... although the little one in the back almost looks like there are threads or something inside. I didn't feel like trying to pull it apart and ruin something that can still work.
ptfarmer
10-10-2018 19:20:35
Which bearings do you need?
ptfarmer
10-10-2018 19:19:41
Looks that way, that's a pretty old rake.
ptfarmer
10-09-2018 16:40:52
I have a MF20 rake, it is different than the Ferguson D-EO-20 rake. McMaster-Carr has all kinds of rubber bar stock that you should be able to make the bushings from.
cow
10-10-2018 09:13:43
 Re: Ferguson D-EO-20 Rake Bushings in reply to ptfarmer, 10-09-2018 16:40:52
Thanks. Another question, my bearings are all usable but not in the best shape. Are bearings for this thing unobtainium?
Cow
10-09-2018 15:15:19
Hmmm... I can't tell. that "disc" part the bearing goes into in the picture doesn't look like mine, mine isn't really a disc it's more like a spoked wheel without the wheel part and a bearing for the bar at the end of each spoke.
Is the Massey Ferguson Model 20 rake a different rake than a Ferguson D-EO-20? I have no idea.
Hay hay hay
10-09-2018 13:35:07
Go to AGCOpartsbooks.com
log in as a guest
put in model 20 rake and massey ferguson
tada!!!!!!! there is the parts diagram.
Check the 195429M2 $3.00 each...a dealer in Kansas has them in stock.
Suggestion...DOUBLE CHECK me...before ordering
oldblue1
10-09-2018 13:24:41
they are great rakes but i dont know where to get bushings. hunted all over to get a belt still havent figured out how to put it on.
