Company Logo Shop Now
TractorLinks.com
Reese Mower
Spencer2598
10-07-2018 07:34:42
Hey everyone, Iím thinking of switching hay mowers in the next year or so and Iíve been looking at Reese drum mowers. The models Iíve been looking at are the 2400 (8 ft) or the 3100 (10 ft) but Iím not sure if I have enough tractor. I would be hooking it on my Farmall 560 that has a fast hitch. If I get the 2400, I know Iíll have to by a conversion kit to get to cat. 2 3-pt. Also, I figure Iíll need some extra weight on the front for the 2400 but I donít know if I have enough tractor for the 3100. Any help would be great! Thanks!
Destroked 450
10-12-2018 22:20:11
 Re: Reese Mower in reply to Spencer2598, 10-07-2018 07:34:42
I understand what your saying to a point but my 8ft 9 blade drum mower pulls a little easier than my 9ft 14 blade disc mower.
The 2400 has two drums with 8 blades, my 8ft Claas has three drums with 9 blades.
Those large drums need to spin pretty fast for the blades to cut the larger area but I noticed in Reese's literature they had slowed the 2400's drum speed to less than any of their other mowers,it looks like they are trying to keep the blade tip speeds the same and added a forth blade to help with the larger area to be cut.
The 2400 is the only 8 ft drum mower I've ever seen with just two drums. Neighbor had a 8ft uniform with three drums.
The 3100 is 10ft but has four drums.
chevytaHOE5674
10-12-2018 19:23:28
I ran an 8' disc mower with the typical small turtles and 2 knives per drum with my ford 5000 and I never had any trouble, tried the reese 2400 on that tractor and it would do it but not at a speed that was productive. The reese mowers are heavy and built like a tank which is good for durability but not good for small tractors.
chevytaHOE5674
10-12-2018 19:08:47
So destroked your comparing to a completely different mower? Lol
The more drums you have the smaller they are thus less mass swinging around. More drums also means more blades so each one has to cut less grass per revolution. All of that means it will pull easier.
Destroked 450
10-12-2018 18:21:11
My old Claas 8" drum mower has three drums with three blades per drum, I've ran it in heavy hay pulling it with my 52 hp 4000 Ford, only time it acted loaded was when hay was to thick to go between the drums. Most of my fields will make 7-8 4x5 round bales per acre during first cutting
Most all hay I mow is done at 6-6 1/2 mph unless the grounds to rough were I drop down from 6th to 5th gear.
I don't know if a Reese mower has the same blade speed as my Claas which can effect how it pulls.
Spencer2598
10-12-2018 18:55:00
 Re: Reese Mower in reply to Destroked 450, 10-12-2018 18:21:11
Thatís what I would expect with my 560. I donít think there is any way I could mow in 4th gear so I would probably be in 3rd most of the time and then if I have real think hay or the rough spots in the field, then Iíll just gear down.
I could see the Reese pulling a little harder with only the two drums since the six blades would actually have to handle more grass. I guess the only way for me to find out would be to actually run one on the 560. To be honest, it will probably be determined by what I can find for sale locally when I go to buy one. Anyone know of one for sale in SE Kansas for sale fairly cheap? lol
chevytaHOE5674
10-11-2018 22:31:29
Belts on my mower are set per the manual. Those heavy drums spinning in 3 or 4 ton to the acre hay at 7 to 10 mph takes some power to run. The large diameter drums and relatively few blades makes them run hard imo. As I say my 12` center pivot discbine pulls about the same and is way more productive.
If I wanted to mow at 4mph I would get a sickle haybine.
Spencer2598
10-12-2018 17:21:21
 Re: Reese Mower in reply to chevytaHOE5674, 10-11-2018 22:31:29
Thanks for letting me know your experience with the 2400. I have an old New Holland 469 that run okay but the rolls are starting to loose their rubber and I know its going to need to be replaced in another year or so if Iím lucky. I figure if Iím changing machines, I should upgrade to something that wonít bog down as easily and in my area, a decent used haybine will go for $1,500 - $2,500. I think I can come up with a decent drum mower for that or just a little more. If I can mow at 6 mph, then I will be thrilled but I know that there are a couple spots that I will slow down. I donít want to break something on the tractor or other equipment and I donít think I sit on the tractor that fast on that rough of ground. My other thought with the 2400 is I might be able to upgrade my tractor in a few years and then I can use it on that one.
Destroked 450
10-11-2018 18:49:41
Sounds like the belts need tightened.
Had the same issue with MIL's mower, belts felt tight, read the manual on tightening procedure resulting the cranking the tensioner two more turns. Afterward the mower ran fine and didn't bog the tractor down in heavy grass.
Destroked 450
10-10-2018 20:23:50
I nearly bought a 3100 but went with a Kuhn instead, Reese says 70 hp for the 3100 but that's to be able to cut hay at 8+ mph.
The same width Kuhn calls for min 47 hp.
Your Farmall 560 is comparable to my Ford 5000 in hp but weighs a little more.
My 5000 handles my Kuhn GMD 2850 TL with no issues and I've mowed several acres with the same mower hooked to my 4000 Ford, tractor had plenty of hp to pull the mower but the mower did push the 4000 some when making tight corners at 6.5 mph.
I like drum mowers and have had a Claas WM30 pull type 8 ft drum for over 20 years, still use it as a second mower at times.
MIL has a 3 point disc mower I used a couple times to mow her hay, PIA to hook up, heavy on the side of the tractor, parked it in the barn 3 years ago and have used my pull behind since.
Far as I'm concerned that 3 point mower can set there and rot to the ground.
Only thing I don't like about the Reese 3100 is the 12' transport width.
Spencer2598
10-11-2018 13:28:14
 Re: Reese Mower in reply to Destroked 450, 10-10-2018 20:23:50
The idea of a pull type over the 3 pt is the main reason Iím even considering the 3100. I agree that they probably say that many hp because of weight and to have a fast ground speed. I wouldnít say my field is extremely rough but, there are a couple places that I slow down anyway with the haybine. I figure if I can run 4 mph or so, then Iím doing fine. I guess itís something Iíll question until I get one and try it...
chevytaHOE5674
10-10-2018 19:09:49
I run my 2400 on a 100hp tractor and in heavy hay I wouldn't want anything less. Get into thick heavy hay and that mower pulls harder than my 12 foot discbine at speed.
Hay hay hay
10-07-2018 08:06:13
I have 3 Reese mowers. 2 are the smaller 2070W fold back, one is a 2400HL vertical lift mower. The mowers are heavy. I run them on a JD 5420 (65HP PTO) cutting thick grass hay, very heavy, sometimes down and tangled. I mow in 4th thru 6th gear depending. When the 2400 HL is vertical it puts a heavy strain on the right side of the tractor and is fairly unstable in rough ground. The fold backs are a great design, easy to use and no hydraulics, but are not for a guy too lazy to get off the tractor and fold it back. And they are heavy when folded, I have 600lb on the front and that handles it fine. Might be touchy with a NF tractor. I think your tractor is heavy enough to handle the 2400 but the HP would be marginal. The 3100 is pull type (I think) and probably a little to big for the HP. If you get one I will pass along some operating advice. The manual is totally useless.
Spencer2598
10-07-2018 08:25:32
 Re: Reese Mower in reply to Hay hay hay, 10-07-2018 08:06:13
Thanks for the advice. Thats how I feel about the 3100 which is why Iím leaning toward the 2400. I would more than likely just get the model that folds back and my tractor is a wide front. The hp for running it is by biggest concern. Iíve read that once they are going, they really donít take that much hp and I know sometimes the manufacturer says they need more hp because of weight issues, hence my reason for asking. If I do get one, Iíll definitely be asking for advice!
Hay hay hay
10-07-2018 10:13:08
 Re: Reese Mower in reply to Spencer2598, 10-07-2018 08:25:32
I don't know how much you are cutting. I bale about 40 acres a year but I have 3 mowers all bought cheap when they went thru an auction and nobody knew what they were. The little 2070w is a gem. Easy to use and very reliable. I usually patch bale, only 5 or 6 acres at a time, square bales for horses so I don't want to get it wet. Consider getting the spreader attachment which works as well as a tedder, except in very very heavy hay they tend to clog. In light hay they save a pass over the field.
