Knot caught on bill hook. I think cam worn out need to replace bill hook(I think). Tried adjusting tension spring on cam. Looked for burs found one and sanded. Hate to buy parts and not fix issue. How do you tell when to knotter frame is worn out? I know the knife arm has to swipe the knot off. It is like the bill hook is not opening up the right time so the knife arm can clean the knot off. I do have knotter manual have tried what it suggested, but it has not helped enough.
So if bill hook tension spring adjustment not helping then cam roller worn out?
I know to change out bill hook you have to take a roll pin out. Is there a easy way to take roll pin out it is really stuck in there.
Thank you for your help.
