I have a 8' Kelly Ryan silage bagger and often have a problem keeping the base of the "backstop" down on the ground, tends to ride up on the bag while filling to the point that I take the Skid Steer and set the lift arms on top of the backstop to hold it down for fear it will rip the bag. My question is how much bag after the knot/bun is tied do you pull off the tunnel to tuck under? How far away do you have the tunnel from the backstop when starting a bag 5' 7'? I use a click type toque wrench to set my 40lbs brake tension which is well below the strech factor of the Up North bags that I use.
Please explain how you set up your bagger. Thanks.
