mW 1500 baler
Harryaroo
I'm having trouble with my M&W 1500 baler-- similar to a krone. I've used it for several years and it has always been a good baler. Recently, hay flops down on the top of the horizontal bars above the pickup-- it comes off of the bale that is forming and lies on the bars which often prevents hay from going under the bars and into the chamber. I've seen this happen before if the hay is damp but it seems to be getting worse. Is there an adjustment i am missing that might help correct?
Take the chain cover off the right side of the baler and double-check if everything is ok . That chain tightener can slip loose.
