New Holland Baler Std & HD Knotters Service Manual
Last year the knoter shear pin on the 271 hayliner sheared for the first time after 12 years and today after the last bale, there was a bang and the pin sheared so I want to go through the machine and i was going to pick up a copy of New Holland Baler Std & HD Knotters Service Manual but the description says it goes back to 273 model. Anyone know if the manual would be of use with the 271?
Thanks,
Warren
Yes it will be very helpful. If you have the operator?s manual for your 271 it is probably just as good. NH has knotter troubleshooting in just about
all baler OM?s.
Start putting common hardware store bolts in there and it won?t be uncommon at all for them to break.
That might be one of the issues, I think i picked up the replacement bolt at a hardware store. However, after looking things over tonight I found the brake pads for the knotter brake paper thin and it didn't have enough "holding power". I could move the needle holder without a great deal of effort. :( Ill check it out further tomorrow after the hay is in the barn.
Thanks for the info guys
Warren
