ShawnMavity
New User
I am searching for an answer on to how to remove the drive sprocket from the apron drive shaft of my NH 516 manure spreader. The sprocket is a 12 tooth and is in the final drive area. It has no visible set screw or keyway with key stock installed.There is a small notch that is 1/4" wide by 1/8" tall cut in the outside of the sprocket hub but no cut in the shaft and no notches or cuts can be found on the back side of the gear. The outer part of the hub of the gear is lobe shaped and I suspect it may be locked like a lock ring for a bearing, however there appears to be no purpose built area to hammer against to rotate the gear. I have tapped on it in the opposite direction of its normal direction of travel but do not want to get to hard with it as the only place to hammer on it is on the cogs. Has anyone seen this type of gear and/or know for sure how to remove them? If you need any additional info to assist please let me know.....Thanks
