Right now I have an international machinery Corp. brush cutter.
5' three point I use with my Farmall 300. It works ok. It is
old and pretty wore out. I got it used and cheap. I usually
just use it for cutting tall grass and weeds. Tonight I tried
cutting some actual brush and it didn't do what I wanted. Brush
was around 1 inch to 1 1/2 inches but it was tall. Probably 7'.
I put the cutter all the way up and backed over the brush hen
pulled over it. Did this several times, each time lowering the
cutter. It just didn't do what I thought it would. Am I asking
too much ? I had a friend come here a while back with a tow
behind new idea 7' cutter with a 60 hp tractor and it walked
right through the same area ! So if I was going to buy a
different cutter what are your recommendations ?
