Square bailer
PP
Any info on the super hayliner 68 bailer would be helpful seen one for sale. Thank you
Made in early 1960. Small capacity 14x18" bale.decent old bales,just slow.Good parts availability still.
http://search.yesterdaystractors.com/cgi-bin/fastsrch.pl
I might still have an original manual for a Super 68 around home if interested.
They seem to make a good bale. You can make the wind rows a good size, but they can be slow. 2.5 MPH is a little too fast when baling with these when we do it. Depending on the size of your tractor you will snap the bolt off the fly wheel to pto. A Ford 3000 will run it but will shake a lot. Our Ford 6610 wouldn't shake when running the baler. The baler also has a Wisconsin THD which is loud, but works good for its age. The previous owner was running a jubilee on the baler. Seems like we are on 68 # 3 or more. My brother and me have used this baler twice baling fields and 3 or 4 times re-baling broken bales.
The photos are from back in 1st of June right before I baled. Sorry for the upside down photos.
[/img]
Decent baler for small operations when in good condition, easy to work on. I still use mine. Can buy operator manual online. Probably hundreds of threads on this baler in archives
Neighbor had one. Couldn't get it to tie, so he traded it for a new MF. Dad bought it. Replaced the plates that kept tension on the twine ahead of the knotters and it was pretty reliable. Chaff would sometimes build up in/under the knotters and cause problems. We go in the habit of raking out the chaff after each load.
