Acquired an Independent Mfg disk that needs a little TLC. Looks like Agri Supply has most of the parts for the disk shaft but ran into a problem with the disk blades. Front half has notched disks that measure 15 inches, only choices from ASC are 14 and 16, no 15. In fact I couldn't find 15" disk blades anywhere on the net.
I need one disk blade to replace an oversized and broken plain blade someone installed in the past. The disks do not look to be worn very much, from looking at the notches 1/2 inch wear would be pretty noticeable. What am I missing, never messed with a disk before.
