Servis Sat 5 cutter/shredder maintenance
mountaineer2
04-14-2017 20:45:07
My tractor came with a cutter/shredder that is old and rough but mows pretty well. I wanted to do some maintenance on it and haven't been able to find how to check/change the oil in the gearbox or what oil to use. Do I just remove the plug on the back and see if I can feel the oil with my finger?
It's a Servis Sat 5 serial#003426
third party image third party image
Texasmark1
04-18-2017 04:44:59
 Re: Servis Sat 5 cutter/shredder maintenance in reply to mountaineer2, 04-14-2017 20:45:07
Adding to other replies: On the pressure buildup and popping seals, or worn seals, replacing that top ½" pipe plug with a vented plug, like OEMs are FINALLY installing on new units will save you some leaks. With the plug on the side, not top, I installed a 90 degree ELL to get the plug vertical then put in the after market vented plug....auto parts stores carry them.
If it gets to leaking on you just suck out the oil and replace it (to the full plug on the side shown) with Lubriplate #109 (in the white plastic tube) at most AP stores, normally used for engine bearings pre lube in a rebuild. It's thinner than #2 grease and thicker than 140 so it gets around to do the lubing but stays where oil leaks out.
mountaineer2
04-17-2017 06:09:13
Great info, thanks
maxwell99
04-16-2017 07:10:47
The gearbox on my cutter is the same as yours,
I would lift the front of the cutter up until the deck is flat,
Take the top fill plug out, then remove the lower (check fluid level plug)
If no oil flows out of lower plug opening, then add gear oil as other member said,
If oil flow out then let it drain down to property level,
Too much oil in a gear box can be as harmful as too little oil, if overfull, pressure builds up in the gearbox and can cause an oil seal to burst,
Other issue, if gear box is low of oil or no oil in gearbox due to a faulty oil seal, you can fill gearbox to proper level with John Deere or case IH corn header grease, this material is more of a heavy thick oil than a grease, it will not run out like gearbox oil, if this works you are golden,
However if the leak is so bad that corn head grease will not stay in gearbox then you have two options,
1. Tear down gearbox and replace seals which rarely works on an old gearbox as the shafts are worn,
2. fill gearbox with regular axle grease, many old gearboxes have run for years with nothing but axle grease,
The newer gearboxs top fill plug have a vented opening to relieve pressure as gears turn but will not allow rainwater to enter
Tx Jim
04-15-2017 08:11:24
YES
mountaineer2
04-15-2017 05:23:14
Thanks for the info. Is the upper plug where you add oil?
Tx Jim
04-15-2017 04:00:06
Oil check plug is surrounded in blue. Changing oil is difficult as there's no drain plug & one must siphon old oil out or turn mower upside down to drain oil out. 85W90 oil should be fine.
third party image
