Hydraulic kicker on bale thrower
taem
12-08-2016 21:50:29
Any suggestions about sourcing a used hydraulic pump and motor for a Massey Ferguson 212 bale kicker? After using a new to me MF 128 baler, toward the end of the season, the kicker lost its power (bales just crept up kicker and stuck) heated up and eventually stopped working, fluids changed, filter changed, no improvement. when I tore down & inspected the pump, the high pressure side was scored. It is a Cessna pump and evidently obsolete. Only dealer motor I could find was in Saskatchewan and very expensive. Rebuild places wont touch it, and I haven't found a junkyard that has a used one. Any ideas?
Determined
12-12-2016 07:50:08
 Re: Hydraulic kicker on bale thrower in reply to taem, 12-08-2016 21:50:29
Long shot.
Case 442,444 yard tractors have a Cessna pump on them.
CCIL swathers used Cessna as well.
jim_uny
12-09-2016 04:50:52
Link
Bob
12-08-2016 21:58:50
Hydraulic pumps are a generic commodity, once you figure out what you have/need.
Note the shaft size and rotation of your pump, then use a pump size calculator to figure out size/GPM's, then surf over to surpluscenter.com.
