White 5100 6r to 4r
StrongsOlivers
03-03-2016 10:32:47
Is it possible to take a 6 row to 4 row?
Thanks
IanC
03-04-2016 06:32:44
 Re: White 5100 6r to 4r in reply to StrongsOlivers, 03-03-2016 10:32:47
All this messing around, wouldn't it be easier to trade for a 4 row?
mudcreek183
03-04-2016 06:07:13
I planted with a 6 row for many years and shelled with a 4 row head with no problems.
Don-Wi
03-03-2016 23:27:10
How good are you at keeping your rows straight? Only issue I can see, if the rows are straight, would be the corners. You'd have to either not plant the corners at all, plan on running some down, or go back and harvest the 2 rows left over separate..
Donovan from Wisconsin
StrongsOlivers
03-04-2016 07:36:24
 Re: White 5100 6r to 4r in reply to Don-Wi, 03-03-2016 23:27:10
Ya going straight shouldn't be to bad. As for corners I always plant square, just because it easier to harvest. Thanks for the input.
donjr
03-03-2016 14:07:24
Take the middle two units off.....
StrongsOlivers
03-03-2016 15:19:04
 Re: White 5100 6r to 4r in reply to donjr, 03-03-2016 14:07:24
??? I dont get what your saying.
donjr
03-03-2016 15:40:19
 Re: White 5100 6r to 4r in reply to StrongsOlivers, 03-03-2016 15:19:04
Think about it- you'll wind up with a four row planter!! ll--llll--llll--1111--1111--11. Just take the end two units off...
-1111--1111--1111--1111--1111-.
StrongsOlivers
03-03-2016 16:47:09
 Re: White 5100 6r to 4r in reply to donjr, 03-03-2016 15:40:19
Ok I see what your saying. I'll take a unit off each end and have a four row. Just wasn't sure if chains would need to be moved. Our could I harvest 4rows from a 6row planter?
centash
03-04-2016 04:24:39
 Re: White 5100 6r to 4r in reply to StrongsOlivers, 03-03-2016 16:47:09
If your fields are square, harvesting 4 with 6 planted is not too hard, just stay on your marker, and plant a 'square' corner.
Ben
