Disc mower leaving large wads
Chuck in Michig
09-24-2014 19:14:37
Have a Krone EC320 3 point disc mower that I"ve not used much. But with some of this late-season lush, wet, alfalfa-orchard grass forage, the old NH 1499 sickle bar won"t get it. The disc mower cuts it well, but tends to bunch it badly. Have promising weather for next few days, so it looks like raking/tedding should spread the bunches so they can dry. Is this typical of disc mowers? No conditioner on this one; don"t know if maybe an integral conditioner tends to even out the swath? Any other options for avoiding the thick bunches?
Eric in KY
09-25-2014 07:53:21
 Re: Disc mower leaving large wads in reply to onefarmer, 09-24-2014 19:14:37
Try not to mow when damp and go faster.
flying belgian
09-24-2014 21:01:59
 Re: Disc mower leaving large wads in reply to Chuck in Michigan, 09-24-2014 19:14:37
Tip it foreword or back until it stops.
LAA
09-24-2014 19:36:24
Most likely what you said, damp and thick, that happens a good bit when the dew is on. You may want to try waiting until the dew burns off and see if it bunches a lot less.
Roger in Iowa
09-24-2014 19:36:24
Try changing ground speed. Maybe faster will help....
Mikein Ky
09-25-2014 17:46:38
 Re: Disc mower leaving large wads in reply to Roger in Iowa, 09-24-2014 19:36:24
Mine bunches when I let the rpm's get too slow. I have to keep it wound up.
