ID this mower
TimnMD
09-11-2014 08:24:26
third party image
third party image
third party image
third party image
third party image
third party image
John Deere? It has been sitting for many years but for $50 bucks couldn't pass it up. Deck is solid, gear box seems good and spins easy with no play.
The pto shaft is stuck, needs tires and need to straighten carrier on one rear wheel. I think it's worth fixing.
Karl in MD
09-11-2014 18:28:32
 Re: ID this mower in reply to TimnMD, 09-11-2014 08:24:26
It's a Long, made in Tarboro, North Carolina. I have its twin.
TimnMD
09-11-2014 19:23:51
 Re: ID this mower in reply to Karl in MD, 09-11-2014 18:28:32
Do you still use yours? Is it a mower worth investing a little$ and time in?
Thanks
Karl in MD
09-15-2014 12:10:14
 Re: ID this mower in reply to TimnMD, 09-11-2014 19:23:51
Yup. Mine has had frame repairs and has rust holes in the deck, but it still cuts grass like a lawn mower. I never tried anything heavier than small brush or saplings.
Bob Bancroft
09-11-2014 16:16:38
I've seen that hitch before, but I can't place it. New Idea?
Rickieblue
09-11-2014 14:05:59
Make sure when you get the PTO shaft apart that you put it back together in phase. It is not in phase now and the shaft will vibrate.
bjr
09-11-2014 15:01:05
 Re: ID this mower in reply to Rickieblue, 09-11-2014 14:05:59
If what I remember 'bout drive shafts is correct, then they can be 90 degrees OR parallel, just not in between those two. bjr
Tx Jim
09-12-2014 03:49:30
 Re: ID this mower in reply to bjr, 09-11-2014 15:01:05
No driveshaft needs to be in phase as RickieBlue stated. 90 degrees
difference in u-joints will vibrate in turns.
Glenn D
09-12-2014 06:54:24
 Re: ID this mower in reply to Tx Jim, 09-12-2014 03:49:30
How do you tell ? is it a matter of lining up the u-joints in some way ?
Mike (WA)
09-11-2014 14:44:19
Good eye, Rickieblue- I'm always amazed at what guys catch from photos on here.
As far as make, its about anybody's guess- those mowers have been made by so many aftermarket outfits (many of them lost to history) that its almost impossible to tell. And nobody has parts for any of them, if they're that old- you just have to be creative (and not so far into them that it will break your heart if you have to scrap it- which you aren't).
ACSam
09-11-2014 09:48:24
Kinda favors a Brillion. I had a similar one years ago and the shade of green looks about right.
Tx Jim
09-11-2014 09:00:45
Definitely not a JD
